Order Ford 9N Parts Online
9N/2N Widget
Phil9N
01-13-2004 19:49:36
I saw Jeb2N's pics last night on the "Parts and Pieces" photo page and couldn't ever recollect my 9N having one those "Widgets" to help release the clutch when applying the left brake. Got up this AM to go to work and stopped at the barn to look. No Widget!Are these available anymore-OEM or aftermarket? I could make one if I had to. Looks nice a neat gizmo to help my poor 9N stop a bit better! Thanks in advance for any help ya'll can give me.
Phil9N
01-14-2004 19:43:07
 Re: 9N/2N Widget in reply to Phil9N, 01-13-2004 19:49:36
It's me, again! After looking at the pictures and taking a closer look at the details, I realized I DO have a Widget! We've had this tractor in the family since Dec. '39 and its been at my house for over 35 years and you guys show and teach me new things every day! Now (after I adjust it) I'll be able to stop it without having to knock it into neutral before standing on the brakes! I think what threw me off in the pic was the clutch linkage lever hanging down. And for those of you who have switched to aftermarket coils because the OEM style costs so much, here's my two cents worth. I bought a 6 volt can style coil from NAPA and mounted it in a clamp on the side of the block, sealed the top of the distributor with silicone , soldered a piece of solid core plug wire onto the cap terminal, sealed that with silicone and slid a boot down over it before the sealer dried. I ran the wire up to the coil,crimped on an end to go in the coil, put a boot on it and plugged it in. After that I ran the necessary wires from the switch to the coil and to the distributor. This has been at least 10 years ago and has worked fabulously since. Thanks again for helping me out.
Jeb2N
01-15-2004 03:21:56
 Re: Re: 9N/2N Widget in reply to Phil9N, 01-14-2004 19:43:07
Good to hear it, Phil.
Yeah, I really should have taken some better pictures. I have a cheap camera, and those pictures were originally intended to go to Red Rock MFG to show them some things about the parking brake positions on the left side of the 2N. They were the only pics that I had that kinda showed where the widget was. Next time i'm out there, i'll take some better ones for my own records. I was wondering how yours got gone since few people ever removed the brake backing plate (you'd have to do that to get the cross shaft out to take the widget off).
Anyways, adjust your pedals to where they line up, put the tractor in first (with widget loosly clamped down, but still can turn) and drive while slowly pushing down on the clutch pedal until the clutch just does disengage. Then clamp down the widget and you should be good to go!
Steve W (NY)
01-14-2004 04:19:57
third party image
What's that long lever for? Is that for easier setting of the parking brake? Where did you get it. By the way, here is another pic I made of this "widget" from my 2N.
Take Care
Steve
Jeb2N
01-14-2004 05:05:46
 Re: Re: 9N/2N Widget in reply to Steve W (NY), 01-14-2004 04:19:57
Hey Steve;
I'm not sure which "long lever" you are referring to. Unless you are referring to the lever in MY picture. Yes, that is an aftermarket reproduction of the Farmech parking brake. They are currently being reproduced for the 8N, but the 8N mounting brackets don't work on the 9/2N. I am working with them to develope the proper brackets for my 2N. Basically, you remove the brake pawl and gear tooth sector and install one of these levers on each side. It is a cam with a lever attached and as you pull the handle up, it pushes down on the brake pawl arm or "widget" depending on which side.
BTW, good picture. I was going to take one similar, but you beat me to it. Hope this helps you out, Phil!
Jeb
Thanks Jeb - Phil B.
01-14-2004 00:15:04
Jeb, Thanks for the pics. I did not even realize that was its purpose. I'll need to adjust because like others, my right brake is worn and left brake is like new....
Phil B.
Chris Brown
01-14-2004 05:04:54
 Re: Re: 9N/2N Widget in reply to Thanks Jeb - Phil B., 01-14-2004 00:15:04
When I had mine apart I switched the brake drums.60 years of wear on the right brake drum.
Jeb2N
01-14-2004 05:06:47
 Re: Re: Re: 9N/2N Widget in reply to Chris Brown, 01-14-2004 05:04:54
That's not a bad Idea. I thought I had noticed slightly more wear on one side than was on the other. I just may do the same. Thanks for the suggestion.
