Order Ford 9N Parts Online
Ford 9N Starter
Adam
01-14-2004 09:54:17
I just bought a replacement starter for my 9N, and I cannot figure out how to get the pin through the starter clutch and starter. It doesn't seem to fit in the hole. I took it back to the shop that I bought it from, and they said I had to just force it in there with a hammer or something. Before I break it, I wanted to see if anyone else had any good advice.
BOB G (TEXAS)
01-14-2004 17:38:55
 Re: Ford 9N Starter in reply to Adam, 01-14-2004 09:54:17
I'm not certain that we are talking about the same parts, but I recently bought a new clutch type starter drive from New Holland. Regardless of what I did, including "squeezing" it, the hole in the starter drive would not line up with the hole in the shaft that is attached to the armature. I took the new clutch type starter drive back to New Holland and they examined it and they couldn't understand it either. They took that part back and I then bought the "old" type starter drive from them and the holes lined up just fine.
Bruce (VA)
01-14-2004 10:03:51
Assuming you have the correct pin..... .you may need to "squeeze" the bendix together to fully expose the hole. The pin, when aligned properly, will be a tight fit, ie, you will need to tap it in w/ a hammer. You may try grinding a little bit off of the edges so that it will get started in the hole, or putting it in the freezer for a while.
