Order Ford 8N Parts Online
8N Wiring Diagram
Al
01-29-2001 13:38:33
Does anyone out there have a wiring diagram for an 8N 12 volt conversion showing both the ammeter and a voltmeter wired up?
Claus
01-29-2001 14:38:59
 Re: 8N Wiring Diagram in reply to Al, 01-29-2001 13:38:33
third party image
Use the wiring diagram from Neil's site. Then all you have to do is run a wire from either side of the ammeter to the positive of the voltmeter and the negative side of the voltmeter to a good ground.
Happy Motoring
Claus
Claus
01-29-2001 14:49:30
 Re: Re: 8N Wiring Diagram in reply to Claus, 01-29-2001 14:38:59
Instead of hooking the positive of the meter to the ammeter, hook it to the switched side of the key. This way the meter would not be on all the time even though it would take 27 years for the meter to discharge the battery.
Happy Motoring
Claus
JimNC
01-29-2001 14:36:44
This link may help.
