SEAT SHOCK ABSORBER?--NEED PT#
BOB
01-15-2004 19:26:45
Need info on the seat shock absorber for tractor.
here is what i have and can read on shock
1-Serial # 510
2-these are the measurements
Closed= 9"
Open= 11 1/2
travel= 2 1/2
3-studs on both ends
4-this shock run thru the spring on this set-up and is behind the seat in a vertical position
5-would Napa have this shock?
6-Many Thanks BOB
UPDATE
01-15-2004 20:42:14
 Re: SEAT SHOCK ABSORBER?--NEED PT# in reply to BOB, 01-15-2004 19:26:45
This seat is a Knoedler seat assembly. BOB
found this info at Smith's web site
Tom T.
01-15-2004 20:29:09
Bob,
If your seat is the MONROE E-Z RIDE, The Monroe shock # should be 66120. There is also a bushing needed to install this shock; The NAPA # for this bushing is 45540.
HTH
Tom T.
Bob
01-15-2004 20:26:50
Here's a recent post from the Deere board about seat shocks, giving a couple of sources. Maybe some of this would apply to the aftermarket seat you're working with.
