Wagner WM-3 Pump GPMs?
Phil B.
01-17-2004 22:03:43
I just spent about two hours looking through the archives for a post I read a while back which gave the flow rate (GPM) for the original front mounted hydraulic pump on the subject loader. Does anyone have this information? I'm considering reusing this pump (with a rebuild) on a custome loader that I'll be making. The new loader will not put as much weight on the front end...
Thanks,
Phil B.
Mike OH
01-18-2004 08:25:32
 Re: Wagner WM-3 Pump GPMs? in reply to Phil B., 01-17-2004 22:03:43
Phil, I don't know if this will help or not, but I see in the literature I have that the pump used on a Wagner WF3 loader is rated at 13.2 gpm min @2000 rpm, @2000 psi max. I have a WM4 myself and had to replace the pump, but I'm not sure what the rating of that pump is, but believe it is the same.
Phil B.
01-19-2004 00:03:35
 Re: Re: Wagner WM-3 Pump GPMs? in reply to Mike OH, 01-18-2004 08:25:32
Mike - Thanks for the information. Funny but that is around what I recall hearing (my memory tells me 14 GPM). I'm no hydraulics expert but from my recent research, this seems a little high for a front loader with 2" rams/cylinders. Of course, the spec. you cited is at 2000 RPM, I wonder if the flow rate drops of linearly with RPM or if these pumps have some kind of step function?
Thanks again,
Phil B.
