WIRING NIGHTMARE
BOB
01-29-2001 18:13:02
STARTED REWIRING THE 8N TODAY, FOLLOWED I THOUGHT NEILS DIAGRAM BUT WHEN I PUSH HE STARTER BUTTON NOTHING HAPPENS, BY THE WAY ALL PARTS ARE FROM FORD, EXCEPT THE SOLENOID AND IT HAS TWO TERMINALS THE STARTER BUTTON NEXT TO THE SHIFTER IS PURE GROUND I CANT FIGURE THIS OUT ANY HELP WOULD BE HELPFUL THANK YOU
Brad
01-29-2001 19:50:32
 Re: WIRING NIGHTMARE in reply to BOB, 01-29-2001 18:13:02
The starter relay on an N tractor is activated by grounding the little terminal. The relay you have installed is for a car or truck. You have to feed one of the little terminals 6 or 12 volts to activate it. The other little terminal outputs 6 or 12 volts during cranking to bypass the ignition resistor. In short, you have to install a relay made for a tractor not one for a car.
BOB
01-29-2001 18:42:07
I DID THAT AND YES IT WOULD CRANK BUT I HAVE ALL KINDS OF JUICE TO THE SOLENOID WHERE AM I LOOKING WRONG
John,tOTG
01-29-2001 18:38:28
Your selenoid is probably looking for juice rather than ground. This is the way with automotive selenoids. Test this by using a jumper wire from the hot side of the selenoid to the selenoid's start post. Betcha it cranks.
John-COLO
skip in ma.
01-30-2001 09:41:38
 Re: Re: WIRING NIGHTMARE in reply to John,tOTG, 01-29-2001 18:38:28
I have early 8n w/cloth wires,found the start wire behind bat,box chewed by critters. I spliced it.It was fine this summer,but now the same problem again,Tractor will not start w/button.I checked area again no mice,rang out starter button to grnd.,and wire to sol.I am scratching my head also,soloniods are different for tractors,one term. and that goes to grnd. to energize i believe.My problem is sol.,or connections i hope. Just to cold to mess with ,been running it by jumping the start wire to grnd,Not much help but I am in same boat. good luck skip
bob
01-30-2001 17:15:41
 Re: Re: Re: WIRING NIGHTMARE in reply to skip in ma., 01-30-2001 09:41:38
thanks all were a great help bought a new 6 volt solenoid today bolt it up pushed the button and presto the engine turned over thanks again
