I don't know if you are on 12v system or 6v, but will throw this out. Add your total wattage on that circuit, and then divide it by the voltage.. that will be amps. for instance.. (3) 55w 12v lamps is 165w... thats 13.75 amps... I would use a 20 amp automotive relay (SPST).. they are cheap and can be found on the shelf at nearly all auto parts stores for adding foglamps.. etc... Fuse with a 15A SB or a 20A FA fuse... might get away with a 15A FA, just depends on the surge current.. and if you turn on all 3 lights at the same time.. or the 2 first then the rear. Pull in current for the relay will be low..I'm guessing less than half amp.. more like 300ma I would guess. That's the nice things about the relay... small wire and switch to control the realy.. and install the relay close to the load/power source.. less money in big wires. now if this is a 6v system.. and you are using say (3) 35w lamps.. that is 17.5 amps... Again.. use a 20A FA if you can get away with it.. or if not a 20A SB.. and as a last choice.. a 25 FA. For a relay.. ( SPST ) you might have to get somehting for a volkswagon?.. etc.. just make sure its contacts are rated at 20A.
If you have other light or load combinations.. just figure out as above.. formula for ohm's law is : E x I = P P / I = E P / E = I I x R = E E / I = R Where E is voltage, P is power (watts), I is current ( amps ), and R is (DC ) resitance ( ohms ).. Soundguy
