Hydraulic In-line Tee Fitting
Phil B.
01-21-2004 22:03:36
I posted a pic in Parts & Pieces of an in-line hydraulic line fitting that I am trying to find. I don't know what its called and am not sure if I can "press" the fitting on my hard-line or if I have to order it pre-installed. Anyone familiar with this type of fitting?
Thanks,
Phil B.
JimNC
01-22-2004 15:29:37
 Re: Hydraulic In-line Tee Fitting in reply to Phil B., 01-21-2004 22:03:36
Phil,
Whats wrong with the existing fitting? Is it leaking around the tube? Are the threads bad? If you can send it to Me with return shipping I might could fix it for you. Depends on what ails it.
Jim
Jeb2N
01-22-2004 03:29:20
Your only option other than replacing the entire line is to get a Tee that has two crimp on "bite-type" fittings. However, I'm not sure that they make those with two bite-type ends and one JIC end. I think they are usually all one way or the other.
Phil B.
01-22-2004 14:38:25
 Re: Re: Hydraulic In-line Tee Fitting in reply to Jeb2N, 01-22-2004 03:29:20
Thanks guys, that is what I was afraid of... I'll look into other options for efficient routing of my hydraulic lines.
Phil B.
Johnski
01-22-2004 00:32:20
Checked out the pic. The fitting you are looking for is part of the hard line assy. It is furnace brazed on and cannot be safely replaced seperately in the field. HTH
