Randy, Just another line of thought, are you sure your tractor is warming up, does it have a thermostat installed in the upper radiator hose. It sounds to me as if the engine and manifold may not be warming enough to atomize the fuel until you've worked some heat into the engine. You can check for a thermostat by squeezing the upper hose (while the tractor is not running, but the engine is warm) and see if you can feel a hard object about an inch and a half long, it should feel about like it has a metal tube inside the hose. The thermostat should be installed at the bottom of the hose, but can move a bit while being used. Even if it has a thermostat doesn't mean it necessarily is getting up to operating temp, you can remove the radiator cap before you start the engine and put an oven thermometer into the coolant, then start the tractor and warm it up. The tempature should reach the area of 180 degrees minimum for the engine to run properly. Good luck. Mike
