6 VOLT COIL
SMARK
01-24-2004 15:07:31
Can I run a 12 volt coil in a 6 volt system?
old
01-24-2004 17:25:18
 Re: 6 VOLT COIL in reply to SMARK, 01-24-2004 15:07:31
You can if you want a big paper weight, I guess it would sort of like trying to drive a car with 3 tires it just don't work
no . . . Dell (WA)
01-24-2004 16:30:25
SMark..... .....NO! ! ! You CANNOT run a 12 volt coil in a 6 volt system..... ...respectfully, Dell
Jim Davis
03-11-2005 15:14:18
 Re: Re: 6 VOLT COIL in reply to no . . . Dell (WA), 01-24-2004 16:30:25
Makes sense, but has anyone actually tried this. I'm in dire straits needing to use my 240 tomorrow for snowblowing, but have no spark. I have juice to the coil and out of if for the dist., spark at the points, but nothing out of the coil secondary, so I figure the coil is bad. Was running, but I'm not even sure the coil that is on it is 6 volt. It's not original.
North of Fargo
01-24-2004 16:30:14
Poorly if it will run at all. You will be putting in only half of the voltage it needs to produce full spark so I would think you will get about half strength spark out of it. If it is a super hot high performance coil it might be enough.
