Well.. polarizing the genny/regulator is just for the charging system.. won't really effect the starting.. and also it really won't polarize if the battery is dead. Lots of places have switchable 6/12v chargers... cheaper ones are low amperage.. like 1.5 amps... more money for more amps...19.99 probably get you a halfway decent one. Also.. tractor supply has about the cheapest 6v batteries I've seen..29.99 etc. Back to the clicking.. somehting is wrong... there should be NO SOLENOID clicking when jumping the starter... You are touching the post on the starter.. and not the incoming post on the solenoid right? If you are getting clicking when touching the post on the starter with your jumper cables.. you've got wireing problems. The oem 3 post solenoid is electrically hot, and it is important that it is mounted with the small 3rd post towards the engine block.. as the relay is internally tied to the incoming hot post, and when you hit the thumb switch, you are merely grounding the 'floating' end of that energized relay.. therby making it click.. if the solenoid is turned around with the third post pointing out.. then yes.. touching the starter stud would make the solenoid hot while jumping.. but then, it won't work the 'normal' way to start the tractor. Give us some background info on this tractor.... has it been working normal? One last possibility... perhaps when you hooked it up wrong earlier, you coocked the solenoids inards.. Make sure you are in neutral... Disconnect the battery wire from the battery to the solenoid, but make sure the ignition is hooked up, if you are trying to start the tractor... jump from the 12v battery.. once cable on the starter lug one cable on the tractor frame... it should spin the starter.. If it doesn't... check like I said earlier to see if the starter is hung up in the ring gear... if the tractor rolls fine.. the starter probably isn't locked up..... time to pull the starter.. Loosen the two long bolts that go thru the starter.. but don't pull them out... the starter will fall apart. After you fish the starter out.. slip a nut on one of those lond bolts to hold it together, then go to a starter rebuilder.. Soundguy
