Order Ford 9N Parts Online
Oil in radiator 9N
Randy
01-30-2004 12:46:01
I got a 9N that runs good, sound good but has oil in the radiator. The oil in the crankcase stays nice and clean, not milky, but it dosn't take long for a film to form in the radiator. What is the first thing I need to be doing to fix it. I'm trying to sell it and it isn't a very good selling point. Thanks
Tom 8N396936
01-30-2004 14:01:16
 Re: Oil in radiator 9N in reply to Randy, 01-30-2004 12:46:01
Randy, had the same problem with my 8N. I was advised by this board to fill the radiator up to where you could see the coolant level and look for bubbles. Sure enough I saw them- it was the head gasket. Not a hard job- just use your manual and take your time.
good luck
tom
george
01-30-2004 13:10:33
Likely to be a head gasket. I would suggest you drain and re-fill oil and water in the short term, but knowing this represent the problem to the purchaser.
