Coil polarity?
North of Fargo
02-04-2004 19:16:58
Does coil polarity matter? (sidemount). I have a 6V coil which has only one terminal marked as BAT. I assume it is for neg. ground but could be wrong.
yes . . . Dell (WA)
02-04-2004 19:32:46
 Re: Coil polarity? in reply to North of Fargo, 02-04-2004 19:16:58
Fargo..... ...yes, ignition coil polarity matters. You can loose upto -40% of your sparkies with incorrect coil polarity. But ignition coils don't care about battery polarity as long as you have the little coil terminals going the correct way.
Modern roundcan coils seem to like to have little (+) and (-) molded into the tops. The general rule is (+) to (+). Meaning connect the coil (+) to the battery (+). On a positive ground system like your 6 volt N-Tractor, that means connect the coil (+) to the points which are ground (+).
On OLD STYLE 6 volt OEM coils as you seem to have, the BATT comes from the ignition switch. This would correspond to (-) coil terminal..... ....Dell
North of Fargo
02-04-2004 19:39:42
 Re: Re: Coil polarity? in reply to yes . . . Dell (WA), 02-04-2004 19:32:46
Thanks Dell. Was going to ask why but went into the archives and what a can of worms to open! Seems to have more to do with which end of the plug sources the electrons. Methinks it's time to try a little experiment!
