Copper Gas Line
RHKirk
02-05-2004 07:24:51
I just read a post about fuel lines and just noticed my line going from the shutoff to the carb is copper. Is this OK? It looks fairly new, so I don't know if they knew what they were doing or not.
Jerry/MT
02-05-2004 14:12:30
 Re: Copper Gas Line in reply to RHKirk, 02-05-2004 07:24:51
Copper will do as a short term fix, but I wouldn't use it long term. Vibration of the line will cause it to work harden and crack. I wouldn't want a gas leak near a hot exhaust manifold. It would be "crispy critters" for your machine! Change it to steel as soon as feasable.
Leader
02-05-2004 13:07:32
Copper is just fine. It will probably out last you.
Evil Steve
02-05-2004 08:43:37
RH-
It will be okay for awhile, but realize that copper and iron aren't really compatable metals.
Further, I believe copper tends to expand and contract more with heat and cold. just keep an eye on connections to avoid fuel line leakage.
Jeff
02-05-2004 07:28:34
that is fine. What I did was just run 1/4 inch brake line and an inline fuel filter. WOrks great
