Cam follower pin removal?
SAm in NS
02-05-2004 13:28:22
I'm helping someone rebuild the back end of his 8N and I think I've finally found the cam follower pin in the hydraulics. It is pretty worn(so is the cam) and I was wondering how you remove the pin so that it can be turned 180 degrees. Thanks, SAm in NS
Rick H. Ga.
02-05-2004 16:23:07
 Re: Cam follower pin removal? in reply to SAm in NS, 02-05-2004 13:28:22
Hi Sam,
As Steve said, brace the linkage in a vise or other suitable support and take a punch and a hammer and knock it out from the back side. It will come out. Put the new one in the same way. It is a tight fit but will go in.
The cam was warn on my 8N as well and I had it welded up with a nickle welding rod and ground it back to shape. My lift system works great. HTH. Rick H. Ga.
Steve IA
02-05-2004 13:45:14
Brace that which hold the pin the best you can and tap it out with a punch and hammer. That's what I did. Gently, as I recall. Then getcha a new one like Jeb says. Steve 8N 169302
Jeb2N
02-05-2004 13:37:28
Don't worry about turning it. A new one is only like $2. You're going to need gaskets anyways, so just order a new pin when you get the new gaskets.
