Sherman Tranny
7783
02-09-2004 20:38:37
I need parts for an auxillary sherman that shifts with a cable. Not quite shure which sherman transmission it is any help would be a helpful.
John Smith
02-09-2004 21:50:57
 Re: Sherman Tranny in reply to 7783, 02-09-2004 20:38:37
I have a prototype here for the new replacement shifter cables for the Sherman step up. They look great. Should have them on the market in 8-10 weeks. Contact me then and I can fix you up with one.
Dave OH
02-09-2004 23:58:47
 Re: Re: Sherman Tranny in reply to John Smith, 02-09-2004 21:50:57
Another problem solved by an entrepreneur. Things are looking up.
Dave OH
Dell (WA)
02-09-2004 21:33:09
7783..... ....Sherman trannys are relative "bullett-proof" except for the cable shifter. The cable rusts inside the sleeve and NO REPLACEMENTS. The other common wear item is the input shaft seal, which is the same p/n 8N-7052-A input seal for all N-Tractors. $3 cheap..... ...Dell
Dave OH
02-09-2004 21:29:06
While they no longer make the cable the other parts should be available. Go to the Smith Tractor Site at www.8nford.com To identify your Sherman.
Dave OH
