OT: Need Help Drilling Holes in 1/2 Steel
Arthur Brestlin
02-12-2004 13:02:58
I want to add two suitcase weights to the frame of my 7' rear blade. It is fabricated from 1/2"x4" steel which is the perfect size to hang the weights from. I need to drill two 7/16" holes on 4" centers to hold the weights in place or icy chunks of white stuff can jar them loose (argh)! The holes are to mount a pair of carriage bolts which would not allow the weights to bounce off the frame. I have been drilling for what seems to be 2 hours, and I am no more that 1/8" deep! Why so difficult? Are there any tricks to speed up the progress? It is very cold (18*) here. I thought about warming up the steel with a torch and possibly using a cutting oil, but so far have not tried either. Any ideas would be greatly appreciated!
John in MI
02-13-2004 10:59:53
 Re: OT: Need Help Drilling Holes in 1/2 Steel in reply to Arthur Brestlin, 02-12-2004 13:02:58
The best way to drill it is with a cutting torch and not a drill.
Bill in WI
02-13-2004 04:06:33
A number of good points already mentioned. To reiterate: Yes, start with a pilot hole, do not take it all the way through. Sharp bits are a must. Absolutely MUST use some kind of lube / cutting oil. Type of material is a big factor. Which brings me to my point: some materials are work hardening, which means the longer you keep working it with that drill bit, the harder it would get. The heat generated by rubbing a drill bit in there is a major contributor to this as well. If possible, move to a new location and try the pilot hole. If you can not get the pilot hole in, you’ll never get the 7/16” hole in.
souNdguy
02-12-2004 20:59:56
If you had a drill press you could use an endmill, and cutting oil.
If I had a drill press and no endmill.. a carbide bit may do it. I would give up on trying to handdrill 1/2 plate.... Would be easier to torch a hole, and/or weld a nut to it and just screw into that.
Good luck
Soundguy
GET YA
02-12-2004 19:56:37
Some COBALT drill bits and a nice 1/2 drill and drill away or should vice this up on drill press
BOB
PloughNman
02-12-2004 17:50:13
Hi Arthur-
Is the drill reversable? Is it rotating the correct way (clockwise)? LOL
If the blade is made of structural steel, forget trying to drill it-it won't. Usually industrial blades are made tough, high carbon, heat treated, quenched, and tempered. Cheaper low-carbon steel blades may be machined if you try a carbide drill. But, you won't do it with a hand drill- it doesn't have the ponies [horsepower] to handle the job. A machine shop with a Bridegport or similar machine might work. Save your high speed steel drills for your lighter projects. HTH
Tim "PloughNman" Daley
old
02-12-2004 15:53:10
Heres and idea, its how we drilled holes in truck frames, You use a piece of chain and hook it around the drill and what you are drilling and by turning the drill you tighten up the chain and putting more force on the bit. Can be a little unsafe and you need to turn the drill so if it locks in the hole it turns its self loose not tighter
Dell (WA)
02-12-2004 15:12:48
Art..... ...sharp drill bits, cutting oil, (plumbers pipe thread oil), 1/8" pilot hole (not all the way thru so the oil doesn't leak out), appropriate cutting speed (large hole = slooooww), steady pressure. Most people don't have the wrist strength to hand drill large holes in hard substances.
While it might seem that stepped up sized hole drilling would be the way to go, its NOT. The major cutting function of a drill is the whole width of the face of the bit. When you try to enlarge from 1/4 to 5/16, yer only cutting with the outter 1/32" of the drillbitt edge. It will get hot and dull innna instant.
Actually, the best bett, would be to haul your part that needs drilling into a real machineshop where they have a drillpress. Probably costya $10. (less than good sharp drillbitt). Oh yeah, carrage bolts arn't that strong, they're grade 2..... ...Dell
Steve(OR)
02-12-2004 13:57:24
As long as we are talking about dull bits - has anyone tried a Drill Doctor - a drill sharpening device that provides a complex built in oscillating motion to correctly shape the cutting edge.
DON TX
02-12-2004 14:14:21
 Re: Re: OT: Need Help Drilling Holes in 1/2 Steel in reply to Steve(OR), 02-12-2004 13:57:24
I've got one. It is easy and very accurate. It will sharpen most types of drill bits.HTH
DON TX
Gaspump
02-12-2004 13:16:27
Depends on the condition or quality of the drill bit as well as the tensile strength and/or hardness of the steel. If the cutting edges are blue or smooth it needs to be re-sharpened or replaced. If you must drill the holes just pick up a cobalt drill from a hardware supplier, use light pressure and cooling oil and it will drill the holes for you. Do not get any drill bit too hot!
Willy-N
02-12-2004 13:11:26
Like Jeff said if it is mild steel put a piolet hole first you can't drill with that big a bit by hand with out one. Mark H.
Willy-N
02-12-2004 13:08:23
What you may be drilling thru is a cutting edge and they are harden steel. I would torch them in if it is and grind them round with a die cutter. Mark H.
jeff
02-12-2004 13:06:11
First, you may have a dull bit. Either find a way to start with a sharp bit or, buy some new ones.
If you need to drill a rather large hole such as a 7/16" diameter, you need to drill a pilot hole....then maybe a 3/16" then 5/16" then a 7/16" bit to finish it out..... keeping the bit cool will be better than heating the metal.
