Order Ford 9N Parts Online
9n diff - still learning
9n141
02-12-2004 17:55:35
Just about the time I think I have learned most everything about the appearances of these tractors along comes a lot of diff. things I didn't know. I love it. Lets all add one or two diff. on 1939 - 1942 -9ns. I will start with double rib fenders, 1939 to early part of 1940. Does any one know when they changed? ( I don't know) LET GAMES BEGIN. BURT.
Jeb2N
02-13-2004 12:17:16
 Re: 9n diff - still learning in reply to 9n141, 02-12-2004 17:55:35
Don't forget the strange 9x32" rear wheels as opposed to the common 10x28s. Always liked the 28's a lot better than the 32's. Oh well.
BOB
02-12-2004 19:38:08
How about the all alumiun dash,steering housing,trans top cover like mine had! and 6" side covers and front axel member,that should get started? later BOB
Willy-N Seen This?
02-12-2004 19:04:47
third party image
Here is one for you. It looks like a Factory Seal on the Lift Control with the number "U 6345" stamped into it. It has a little original paint on it marching the part paint and this part has not been repainted as far as I can see. It is sealed around the Casted part on rhe control. I wonder if it is a inspection tag from when it was built?? Mark H.
Bob
02-13-2004 07:07:59
 Re: Re: 9n diff - still learning in reply to Willy-N Seen This?, 02-12-2004 19:04:47
Willy,
Years ago, in our area, when a dealer would trade on a piece of equipment, and put it on their lot, they would install a tag like yours to identify the unit. Some were embossed with the dealer's name, and some just were serially numbered.
Jeb2N
02-12-2004 18:57:16
Well, I just found out about the Cast Aluminum Radiator cap. Went back to the originality guide and sure enough, it was in there. Just hadn't noticed it before. That and the fact that the left and right brake pedals are identical. Always found that funny with the left brake having the little nub sticking out for the parking brake!
Willy-N
02-12-2004 19:08:12
 Re: Re: 9n diff - still learning in reply to Jeb2N, 02-12-2004 18:57:16
Mine does not have that on the left side just the hump in the pedal. Ser# "9N 37425 star" Mark H.
Willy-N
02-12-2004 18:18:26
I thought the double ribs were in 1939 only according to what I have read. Mark H.
9n141
02-12-2004 18:36:05
 Re: Re: 9n diff - still learning in reply to Willy-N, 02-12-2004 18:18:26
My 1940 ser# 9n12332 and 9n12433 both have db ribs.Also have one other with db rib. BURT.
Jag
02-12-2004 22:54:21
 Re: Re: Re: 9n diff - still learning in reply to 9n141, 02-12-2004 18:36:05
Burt don't forget to add that the first double rib fenders had around 12 rivits. That seemed to end around # 6000???? Just recently there was a 1940 floating around Bethel Oh that is said to be owened by the original family and it has 1 1 rib and a 2 rib?? I will try to see if I can find out the serial #.It was for sale on e-bay about 6 months ago but I dont think it sold? Thanks Jason Grooms... (jagperf@aol.com)
Willy-N
02-12-2004 23:02:12
 Re: Re: Re: Re: 9n diff - still learning in reply to Jag, 02-12-2004 22:54:21
Mine has 1-smooth and 1-rivet axle? I belive one may have been broke at one time but who knows? Using up inventories?? Mark H.
Jeb2N
02-13-2004 03:41:18
 Re: Re: Re: Re: Re: 9n diff - still learning in reply to Willy-N, 02-12-2004 23:02:12
If it has one smooth, then originally, both were smooth. The reason they went to the riveted design was the huge smooth casting was prone to getting air bubbles which weakened the casting and later broke. Most likely, one of them broke and was replaced with the later design. This is common and that's why smooth hub axles are somewhat rare and need to be taken care of due to being fragile.
Jeb
