Starter Update
RHKirk
02-12-2004 19:14:10
Well with everyones help I got the Bendix back on the starter and in the tractor. It starts fine now. After I put it in I found some instructions in the box. The Bendix is the newer type without the spring. It said I needed to drill a new hole in the shaft 1/2 inch closer to the starter. I did not do that. It all works, but my guess us the bendix is only engaging the front edge. Will this probably make it not last as long as it should? I think I'll buy another for a backup just in case.
