Undoubtedly a loader would be prime for moving and stacking dirt. Depending ont he height of your trailer.. you might be able to dump dirt into it using your rear scoop.. just have to measure the dump height... one issue will be getting the dirt far back into the trailer. Unless you have a dug out spot to park the trailer in.. and dirt rampway up to it, so that you are dumping over into the back of it.. it will probably be more hassle than its worth. I moved about 10 yards of dirt with a 30" rear scoop and a 21hp jap tractor while prepping arounf my house as it was being built. So moving via tractor and scoop is viable. I think you'll find that your pile will not go any higher than your scoop drop height. You can push it up some with a box.. but not much. Additinally, you could ramp one side of it to pull up on as you build it.. or even make it like a small berm, driving up on it dumping, and driving down the long sides... kind of like how an heavy equipment earthmoving scraper pan would dump out. It is going to be a bunch of work either way. I fthe material is iin a stock pile... I would mount the scoop facing the rear.. and take advantage of the jub's live hyds and back into the pile while lifting. Shorten the toplink a bit to provide a good bite, and being angled slightly back when lifted will hold your load of dirt as you travel. If you had a friend with a loader or bull dozer you would be set.. Soundguy
