Four or Six blade fan
NorthTexas
02-15-2004 16:38:07
Four blade and six blade fans for the radiator. Is it true that a four blade fan will give you a little more power? The six blade fan having to pull more air is it using more power or not? Just something that I though about coming from my old hot rod days.
NorthTexas
John IA
02-15-2004 17:44:06
 Re: Four or Six blade fan in reply to NorthTexas, 02-15-2004 16:38:07
North Texas, Something else to throw in the mix. If my memory serves me correct, 1 of those fans pulls air and the other pushes air. Not for sure but I beleive the 6 blade fan pushes air. John
Jeb2N
02-16-2004 07:24:43
 Re: Re: Four or Six blade fan in reply to John IA, 02-15-2004 17:44:06
4 blade fan came in two varieties: Standard puller fan (blows on engine, pulls air through radiator) and a "winter fan", which had smaller blades and didn't cool the radiator off as much.
The 6-blade came in both push and pull varieties. All in all, you had 4 different fans to choose from. I have never seen or heard of a 4 blade push fan.
Jeb
cfm..John,PA
02-15-2004 17:01:54
The more cfm of air, the more hsp. required to move it.
Phil B.
02-16-2004 21:19:21
 Re: Re: Four or Six blade fan in reply to cfm..John,PA, 02-15-2004 17:01:54
The hotter the fuel and air (gas tank) gets, the less fuel/air that can get into the engine = less power. I wonder which wins out - less air flow to preserve crank horsepower, or cooler/denser air/fuel mixture (?). Of course, in some parts of the country (cold) this is a no brainer. Here in SoCal, I'm pulling for keeping everything as cool as I can.
Phil B.
