cracked block
Ron Miller
02-15-2004 18:14:18
Hi, I rebuilt an 8n and now it leaks water between the block and #1 cylinder sleeve. I've been told that if you use sleeve retainer it might stop the leak. Do you have any ideas?
Thanks
raytasch
02-16-2004 05:19:07
 Re: cracked block in reply to Ron Miller, 02-15-2004 18:14:18
Ron, Many of these old blocks are rusted through from the water jacket to the sleeve. Sleeve sealer may work. My machine shop guy will overbore the block, install an oversize sleeve, and bore it to standard bore.
ray
Ron
02-16-2004 07:11:49
 Re: Re: cracked block in reply to raytasch, 02-16-2004 05:19:07
Thanks Ray, what do they usually charge to bore out block and a new sleeve? I reinstalled the sleeve with sleeve sealer and it still leaks.
Thanks
