Help Jerry
RandyinWNY
02-17-2004 09:53:39
Jerry, GREAT machines are'nt they. Let me know exactly what you do to your tractor. Mine sounds exactly the same. Idles at 900rpm, full throttle at 1700rpm. I think I need some adjustments to lower the idle and rev up the full throttle BUT not really sure what or how. I am a new owner and just learning about the "N" tractors. ANY help from you or anyone is always GREATLY appreciated.
Thanks....Randy
Jerry L / az
02-17-2004 12:40:51
 Re: Help Jerry in reply to RandyinWNY, 02-17-2004 09:53:39
I checked the archives under carb settings and govenor rod and printed out the information, My throttle to govenor rod needed to be lengthened to allow the govenor to carb rod tocome up on the stop for the Idle adjust screw at low end of the throttle quadrant. and the govenor high speed adjust screw at the high end of the throttle quadrant now I'm idleing at 650-700 rpm's kind of pulsating. At the high end or full throttle I can only get 1700-1800 rpm's tryed adjusting the carb but it has no effect back to the research...Jer if you get you'rs figured out give me a shout
