Here is what I did to install a very useful paper filter..... 1. (1) 12" piece of 1/4" brake line 2. (1) 1/4" hydraulic brake line union 3. about 12" of rubber fuel line 4. Paper filter from NAPA designed for gravity system. 5. (2) 1/4" male hose barb adapters (threaded to accept the female union and threads of the carb) Take the 12" section of brake line and screw it into the sediment bowl assembly..... .. Then, screw the female union onto the end of the brake line. Next, take the 1/4" hose barb adeapters and thread them on the end of the female union and one into the carb. All you have to do now is run some hose off the end of the upper hose barb and attach it to the filter...then from the bottom of the filter to the carb. I like a clear plastic filter because I am just that way. It seems to work just fine and mine has caught quite a bit of gunk and crud so far. Should put an end to the stuck float condition!!! If anybody wants a pic of the setup just let me know and I can send it!
