Order Ford 8N Parts Online
Ford 8n 1952 Schematic
abraham Duenas
02-20-2004 15:35:39
Anyone know where I can see a wiring schematic diagram for a 1952 8n. Please help!
As you requested
02-20-2004 15:52:37
 Re: Ford 8n 1952 Schematic in reply to abraham Duenas, 02-20-2004 15:35:39
Go here
Question..John,PA
02-20-2004 17:00:50
 Re: Re: Ford 8n 1952 Schematic in reply to As you requested, 02-20-2004 15:52:37
According to the 9N diagram, does the ignition switch have to be closed to send power to the headlights?
raytasch
02-20-2004 17:55:14
 Re: Re: Re: Ford 8n 1952 Schematic in reply to Question..John,PA, 02-20-2004 17:00:50
John, You are seeing what I am; if you are looking at the linked schematics that is what you are seeing. IMO the ignition switch is too light duty to carry the additional draw of the lighting circuit. IMO, a better place to connect the headlights is from the main lug on the terminal block. Much heavier wireing. Stay away from the primary ignition circuit. Of course you have to remember to turn your lights off. Remember, headlights were a dealer installed item so they may have been hooked in anywhere. ray
Thanks..John,PA
02-20-2004 18:11:35
 Re: Re: Re: Re: Ford 8n 1952 Schematic in reply to raytasch, 02-20-2004 17:55:14
Thanks. I was hopeing that someone would pick up on this.
