Order Ford 9N Parts Online
9N ignition wires got hot and melted !
Richard
02-22-2004 06:16:17
My 9N with a 12 volt system had a dead battery today and it should not have the battery is new.When I put a new battery in it I ran it for a few minutes then my wires smoked and my tractor is dead. Both wires from the ignition melted. Do I have a bad resitor or regulator? Thanks for any suggestions. I am going to replace the switch and the resistor and maybe the regulator. How can I be sure which is the problem or if its the alternator ?
Dell (WA)
02-22-2004 07:43:13
 Re: 9N ignition wires got hot and melted ! in reply to Richard , 02-22-2004 06:16:17
Richard..... ...Ain'tcher regulator 'cuz its inside yer alternator, ain'tchur alternator 'neather, but to make you feel better, most autoparts stores offer "free" testing.
Wires smoke because they get shorted out, ONLY the battery has enuff power to smoke a wire. Your short will be found at the end of the smoked wire fartherest from the battery. Replace your burned wire and you'll probably "fixx" the short without even recognizing it..... ..Dell
Richard
02-22-2004 12:10:30
 Re: Re: 9N ignition wires got hot and melted ! in reply to Dell (WA), 02-22-2004 07:43:13
I thought that was probably what happened.My ignition switch is fried, I will replace that and the wires and se what happens. Thanks
