Rebuilding hydraulic cylinders?
Reno J.(NE)
02-22-2004 09:08:00
My cylinders are leaking on my loader. How hard is it to rebuild or is it better to just replace?
Hal/WA
02-22-2004 21:40:07
 Re: Rebuilding hydraulic cylinders? in reply to Reno J.(NE), 02-22-2004 09:08:00
It might be hard to find just the right replacement cylinders and they are costly. Fixing your existing cylinders can also be costly or relatively cheap, depending on just what is wrong with them and the type you have. If the chrome plating on the rods is not too badly worn or pitted, or the rods bent, it may not cost much at all to fix the cylinders. If you need to replace the rods, or have other parts machined, bring your checkbook.
I would suggest removing the cylinder that is leaking the worst and taking it apart to see how it works and what is worn or broken. Single action cylinders that I have worked on were very simple with seals only at the joint between the rod and the barrel. Double action cylinders also have internal seals that won't leak on the ground, but might allow a loader to slowly drop from a raised position. Of the cylinders I have worked on, some come apart by the joint where the seal is unscrewing from the barrel. Others come apart by removing snap rings and others unbolt. If it isn't obvious how they come apart once you have the outside cleaned up, I would suggest taking the cylinders to a good hydraulic shop for an estimate.
The hydraulic shop probably has or can get proper seals. Having the shop rebuild the cylinders can get expensive--I paid over $400 to have the cheapest shop in town rebuild a double action cylinder--but they guaranteed their work. Another single action cylinder I fixed by replacing the washerlike stack of seals cost me less than $20 to repair and get to stop leaking. But I know that the rod really should have been replaced, as some of the chrome is rubbed off. But that proper repair will have to wait for another day. I use that tractor and loader all the time and in 2 years since I repaired that cylinder, it hasn't done more than seep a little. OK for now! Good luck.
Fessman
02-22-2004 16:31:53
Reno,
Hercules hydraulics is a catalog house that has a ton of cylinder rebuild parts. Not sure what they have on the net, but you might do some searching to find out.
Fessman
old
02-22-2004 09:46:17
They aren't to hard to rebuild, just a pain in the ^%$##. Take them apart and then take those parts to a tractor dealer for a match up, biggest thing to worry about is getting the seals etc on in the right way
