STARTER DRIVE FUNK FORD
ARCHIE
02-23-2004 14:06:54
DOES ANYONE KNOW OF AN AUTOMOTIVE OR TRUCK OR TRACTOR STARTER DRIVE THAT WILL REPLACE THE ONE USED ON A FLAT HEAD 226 IN A FUNK CONVERSION ?
Mike
02-24-2004 03:22:38
 Re: STARTER DRIVE FUNK FORD in reply to ARCHIE, 02-23-2004 14:06:54
Archie,
You might want to check around and see if you can find someone in your area with a '49/'50/'51 Ford containing a flathead 6 so you can compare the starters.
I have one in southwest central PA but he never comes out in the winter, it's bad for his health (kinda' like that grounghog :o) Good luck on finding one to look at, you might try antique car clubs in your area. And then hope the fella' doesn't charge you too much for looking :o)
Mike
Dell (WA)
02-23-2004 20:02:42
Archie..... ...I ain't no expert on 6-cyl Funks, but this is what I kinda figgered out. Because ALL automotive engines run the same direction, all starters turn the same direction.
The Funk conversion starter problems lies with the OEM 6-cyl starter motor being on the right side of the engine ...AND... the N's tranny starter hole is on the LEFT side of the engine. SO Funk made somesortta "starter adaptor" to make things fit and work.
From there, it getts murky. Don't know if'n they used a standard 6-cyl starter motor, or if'n they used the N's starter motor ...OR... some other starter motor completely. Or if'n had a reverse bendix screw...or...gack..... just donnna know.
BUT several years ago, I helped 'nuther feller do a Flathead 60 V-8 conversion and kept his starter motor on right side of engine under exhaust manifold by changing to geardrive "Nippondenso" 12 volt starter motor. where the starter drive doesn't need to extend into the tranny housing.
Outfit was selling on E-Bay outta Michigan using a "cutesy name" that wasn't the real company name. Unfortunately, I lost the e-mail address or the real company name. He had adaptors made up for numerous old engine applications, including Flathead V-8's and N-Tractors 4-cyls, but I don't remember for 6-cyls. I once did an E-Bay search but their archives only go back 6 months.
So heres the "clue", go web searching for "Nippondenso", ya just might get lucky.
Heck, do an N-Board search to get ya started..... ..Dell
