Order Ford 8N Parts Online
8N 3pt lift
Ryan MD
02-24-2004 05:39:26
When the 3 pt on my 51 8N is in a low position I am able to manually lift the arms to the highest postion without any resistance. Is the system suppose to work like this or should the arms hold the position they are in?
Thanks,
Ryan
ZANE
02-24-2004 05:44:50
 Re: 8N 3pt lift in reply to Ryan MD, 02-24-2004 05:39:26
That's the way it is supposed to work. It ain't broke!
The ram cylinder(hydraulic) ram rod is not hard connected to the ram cylinder. It rests in a concave socket in the center of the piston and when you lift the lift arms the ram rod just lifts out of the piston socket but is not able to become dislocated because it is still held in the bore of the ram cylinder.
Zane
