Order Ford 8N Parts Online
oil in water - radiator for 8n
P Roldan
02-24-2004 13:43:18
Can anyone help with this problem. I'v got oil in the radiator mixing with the water, but now water in the oil pan. noticed this when i checked water lever from the radiator cap.
Dell (WA)
02-24-2004 14:59:50
 Re: oil in water - radiator for 8n in reply to P Roldan, 02-24-2004 13:43:18
Roldan..... ....the oily sheen you're seein' floatin' ontoppa yer radiator fluid ain't oil, its combustion by-products forcing their way past a leaking headgasket.
Re-torque your headbolts to 70 ft/lbs or if'n ya gotts stud-nuts, torque to 55 ft/lbs. You can tell the difference between bolt heads and stud-nuts, can't you?
If'n cylinder headbolts were tight, then its too late, might as well plan on replacing your headgasket. Check your I&T FO-4 for proceedure..... ..Dell
