adjusting valves ?
Rick
02-24-2004 16:36:43
I have the special tapet wrenches that keep the tappets from turning. I ground a wrench as described in the manual. When I turn the engine so the valves are closed, the tappet is down so far that it seems like it is going to be very hard to get in there with the ground wrench. I can see it but boy, it sure looks like very little clearance to get the wrench in. Any tips???
Cap-N-ID
02-25-2004 14:37:56
 Re: adjusting valves ? in reply to Rick, 02-24-2004 16:36:43
Hey Guys -- Take a look in the archives, if I remember correctly I saw a post from Zane (I think)a few days back that layed out what sounded like a good procedure for adjusting the valve clearences and it didn't even require the special little wrenches (which he felt were prone to break).
--Cap--
dave8n
02-24-2004 16:49:51
Rick,What i did is take out all the sparkies,Engine will turn real easy.Then you can turn the engine by hand and get tappet up where you can ajust and turn back and recheck..
threads per inch ?
02-24-2004 16:53:43
 Re: Re: adjusting valves ? in reply to dave8n, 02-24-2004 16:49:51
great idea. and to add to that, IF we knew the threads per inch on that thing, we could make an estimate of how much to turn it. Does anyone know the threads per inch on these adjusters?
tom(ont)
02-24-2004 18:38:06
 Re: Re: Re: adjusting valves ? in reply to threads per inch ?, 02-24-2004 16:53:43
Hey Rick..Couple questions,where you get them tappet wrenches, and how hard is it to turn those things...I,ve herd they can be bend those tappet wrenches? Haven't got to my 2n tappets yet..tom(ont)
