Question from a NOOBIE
PNR123
02-24-2004 17:47:01
I'm one of those "city folks" who is moving out to the country so I'm ready for your "comments" , but first I have a question pertaining to landscaping . The acreage we've purchased was/is pasture and I want to seed 1.5 - 2 ac with grass for a yard , my question is.....will a 6' cultivator behind my 8N be aggressive enough to tear through the hard packed pasture to get down to the soil or is there a better way , short of plowing & discing?
thanks in advance
DJ in PA
02-25-2004 06:39:42
 Re: Question from a NOOBIE in reply to PNR123, 02-24-2004 17:47:01
Rent a moderen utility tractor, and land scape attatchments and you will have a beautiful job finished in three hours. That is if you want a (lawn quality) result.
Other wise you can plow, disc, and cultipac, and get about the same results, but you will be messing with it for a couple days.
RB/CT
02-24-2004 19:32:01
Could try Frost Seeding it. (Do a search for frost seeding), the snow must be gone and the ground still frozen, done by early spring, might get a 50-70 percent success rate with clover. Doing some myself soon with Medium Red Clover and Birdsfoot Trefoil. Or Hire someone with an Overseeder. Good luck.
Dale in I'n'
02-24-2004 18:21:07
Would second what DallasGa said. I'm the same as you. Bought a place with 3 acres a couple a years ago. Bush Hogged it off with the 9N and have kept it down with a finish mower. Boy that Woods and the "N" have it lookin fantastic. The weeds were shoulder hi when I started over most of the property. Now, under the dug out apple trees, all I haveta worry about is apple cores.
WaterBoy in MI.
02-24-2004 18:12:28
Hi Noobie:
Best I can say is to call your local agricultural agent. He?She will meet you at the property site. They can advise you best.
DallasGa
02-24-2004 18:09:37
Ha 123, A pasture is no more than an over grown lawn. If you mow it low and regularly, you shouldn't need to start over. I have 7 ac. of pasture that look like a jungle in Oct. and now look like a golf course over seeded with winter rye, the result of a good winter mowing. If the surface is rough though your disc should have no trouble knoking down the high spots.
