oil pressure relief valve
Rick B. Silvert
02-26-2004 23:27:40
I have my engine oil pressure relief valve out and noticed that the seating surface has a small "flat" machined on it, as if it were to allow a slight amount of "bleed off" of oil pressure while the valve is seated. Is this correct? I expected to find a valve with a unbroken seating surface around its circumference.
yes . . . Dell (WA)
02-26-2004 23:46:24
 Re: oil pressure relief valve in reply to Rick B. Silverton OR, 02-26-2004 23:27:40
Rick..... ...yes, your oilpressure relief valve is supposed to have that "flat-spot"..... ...Dell
Dave OH
02-27-2004 21:40:37
 Re: Re: Re: oil pressure relief valve in reply to bud, 02-27-2004 14:33:30
Probably your old one was sticking or the spring was bad. It should have a slight bleed (the flat spot) as Dell said. Just 8N's don't sell junk, but I would call him about it.
Dave OH
