Governor Oil Leak
Bama8N
02-05-2001 11:54:56
I have an oil leak around the throttle control shaft of my governor. The parts book only shows a dust seal on this shaft, so I ordered one from Don. The problem is I can't get the shaft out. The yoke on the inside is pinned and you can't get a straight shot at it to knock the pin out. Anyone ever removed the throttle shaft from the governor?
geo in Mi
02-05-2001 19:17:31
 Re: Governor Oil Leak in reply to Bama8N, 02-05-2001 11:54:56
The pin is tapered, and it will line up through the oil coupling hole so you can tap it out.
Martin
02-05-2001 19:12:03
I recently replaced the bearing and seal in my 8N and had to remove the throttle shaft. The pin you refer to is tapered with the thick end to the inside of the housing. My assembly is the type with an oil line going to the back of the governor and I was able to drive the pin out the threaded hole where the brass oil fitting elbow screws into. To reassemble, I had to reach into this hole with a pin punch and seat the tapered pin through the hole with a bit of red Loctite.
Hope this helps.
Jerry WI
02-05-2001 17:08:21
Bama8N, Check out the following link. It is haow to rebuild the governer complete with pictures.
www.si-inc.com/8NOverhaul/
also check DonNAZ in the archieves he is the author of this article.
