Patent/data plates
Old George
02-05-2001 18:00:37
Does anyone have a good method of cleaning up/restoring the aluminum data plates that over the years have been scrathed,painted, etc? I am mainly thinking of the patent plate on the upper steering housing, but would also like to clean up the data plate on the Ferguson mower mount bracket and an old Dearborn scoop and Carrington back blade. I have heard Don has them(patent plates) and they look pretty good, but if it can be done I would like to restore these old ones. As always, thanks in advance.
Alan Esch
45 2N kit 183513
Appreciate the suggestions
02-07-2001 17:26:40
 Re: Patent/data plates in reply to Old George, 02-05-2001 18:00:37
The brass seems much better than the aluminum one I have to work with but I will give it try. Thanks again! Alan
swavo
02-06-2001 05:32:02
Mine was made of brass, I used Simmichrome( a very fine polishing compound) it cleaned up real nice. I would then reccomend sealing it with a clear lacquer or at least a good coat of wax to prevent oxidation.
Mike
Tyler (MD)
02-06-2001 03:38:42
I used a fine steel wool. Cleaned up nicely. Don't take too much off of the plates. Then you can read the numbers.
third party image
Ya can't see the numbers too well. Too much glare. :-)
I masked off and sprayed some clear poly on the plate to keep it from tarnishing again. It's been fine for 3 years now.
Tyman
JimNC
02-05-2001 19:27:30
I wanted to do the same thing. All I know is don't bead blast it!! I destoyed mine.
