Order Ford 8N Parts Online
Re: '49 8N Timing Problem
Phil (AZ)
02-05-2001 22:45:52
Jim, The front mount dist is almost fool proof, mechanical pre-determined dwell (its not a lobe)
The Timing ADJ should always be in the center of its range, IF the centrifugal Advance is working
and not hung up.
Remove your Dist, Points, and the Clip Ring that holds the Plate (note location of Loop.) and the Timing adj screw. You can now pull the Plate & upper bushing up and off the shaft.
The Shaft is now free to be pulled UP and out of the Dist body. The upper and lower Shaft Assembly is connected together (in Rotation) by the weights & Springs of the centrifugal Advance.
You may have a broken spring or its just rusted up
so that the shaft is not returning (Rotating) to its starting(relaxed)position
Good Luck,
