Gas Shut off
Al Amstutz
02-08-2001 19:04:44
As a new owner of an 8N (low serial # 1947) I have been told to shut off the gas each time the tractor is shut off. I am wondering if everyone (or most everyone) does this, or was I advised as a "safety precaution"? Just curious
chuck
02-09-2001 09:49:20
 Re: Gas Shut off in reply to Al Amstutz, 02-08-2001 19:04:44
I agree with all the issues on the safety of shutting off the fuel when you are done. However, I have been running an experiment for the last 13 years on my '52 8N. I only shut the fuel off to work on the carburetor (two maybe three times that I remember in that period). I haven't had any of the identified problems mentioned on the board. Also, some people recommend running the carb out of gas. Well I have found that this unnecessary and I theorize it's worse than leaving the carb full. This is based on owning lots of engines of all types. You cannot remove all of the gas in the carb so when you run it down there is a small amount left in the bottom of the bowl. It takes less time to evaporate this small amount than it would a bowl full. So you end up leaving more dried deposits on the bottom of the bowl. Now I have rarely ever taken a carb apart that was dry inside, there is always some gas in the bottom unless it has not been run for years. I don't think that bowl drying out is a problem for regularly used equipment (unless there is a leak and then there is nothing left to dry out). I have searched for gummy/dry deposits in a lot of carburetors and only found them in carbs that have sat static for years.
chuck
436244
sfurn
02-09-2001 04:44:52
I never shut off the fuel valve or remove the key & I've never had the first problem caused by doing this --- had my 8N for 5 years. But after reading all these posts I just might mend my ways!!! My advice --- these guys are smarter than me....
Steve - Northern Indiana
Dave 2N
02-09-2001 04:31:36
My grandfather taught me to drive on his 2N, a long time ago. I can still remember him telling me that you always turn the gas off when you were done using the tractor for any length of time. I never questioned him and even today, I still turn off the gas on my 2N when put it away.
Paul Haas - -Pine Island MN
02-09-2001 03:41:35
One person on this board could never remember the gas shutoff so went the no-brain method and installed a electric fuel shutoff for a Melrose Bobcat skidloader wired to the coil. Key on - fuel on, key off - fuel off. Nameless individual wasn't nearly so forgetful ten years ago...
bg
02-08-2001 22:33:37
Most advise shutting the gas off so it won't run through the carburetor if the needle valve doesn't close completly.
Fast Ed Ohio
02-08-2001 23:00:49
 Re: Re: Gas Shut off in reply to bg, 02-08-2001 22:33:37
Yep, shut it off after your done for the day,me and all my n friends do , it will prevent possible problems.
hey busdriver
02-08-2001 22:30:52
I think you will find if you turn off the fuel and then run your tractor till the carb runs out of gas you will be better off, saves a buildup of vanish in the gas in case you don't use the tractor for awhile.
Stan
Steve IA
02-09-2001 02:00:34
 Re: Re: Gas Shut off in reply to hey busdriver, 02-08-2001 22:30:52
If you do this, don't forget to turn off the key when it stalls. If you don't, you may end up buying a new coil. BTDT Steve 8N 169302
hey busdriver
02-09-2001 09:22:39
 Re: Re: Re: Gas Shut off in reply to Steve IA, 02-09-2001 02:00:34
That's true , but if you get in a habit of turning it off and taking the key out of the ignition , it isn't any different than when you leave your vehicle that you drive on a daily basis. To me , sometimes a pain I go to turn on and find that my keys are in my pocket.
Stan
Steve(CO)
02-08-2001 21:18:31
I think most folks close the gas valve when they shut the machine down. I always make sure that I do when I've finished for the day.
younganddumb
02-09-2001 01:31:43
 Re: Re: Gas Shut off in reply to Steve(CO), 02-08-2001 21:18:31
I never used to shut off the gas.Now I do for the simple reason that if your float sticks open gas will contnually run through the carb,fill up the intake tube and dump into the cylinders filling them up.When you hop on and try to start it, it will "lock up". Liquids are not easily compressionable and will most likely damage your engine
Bri9n(Ont)
02-08-2001 19:33:19
I've learned a tremendous amount from this board, including the two basic things I do every time I turn off the tractor....i)turn off the gas valve and ii) remove the ignition key, and hang it in the same spot each time...its not the key removal itself thats important but this way I never leave it turned on by mistake.....Brian.
MikeC...Exactly Right!
02-09-2001 08:41:43
 Re: Re: Gas Shut off in reply to Bri9n(Ont), 02-08-2001 19:33:19
The wisdom of the advice on this board is highlighted by your words!
