Carburetor Leak
Rich
03-01-2004 03:50:49
Yesterday, I was supposed to have my grand starting of my 8N after a year and one half of rebuilding. Did not happen! Carb was leaking gas from the little drain. Researched the archives. Took the carb off to check the float. It does float - so no leaks in the float. Checked the float valve by blowing air through the elbow assembly while holding the valve and no air escaped. Checked the float setting to make sure it was 1/4 inch off the gasket and found that one side was 1/16 of an inch off (greater than 1/4). Could that 1/16 error have caused the leaking? Also, is there a way to check to determine if the main nozzle gasket is sealing properly? I read in the archives that some use a gasket sealer there. Is that advisable? I'm a missing anything else? Thanks much.
ZANE
03-01-2004 04:49:23
 Re: Carburetor Leak in reply to Rich, 03-01-2004 03:50:49
The Marvel carburetor is imfamous for leaking as you describe. The problem is that it is just not very close tolerance in manufacture and fit and the needle can fail to completely seal the gasoline off. That's the reason there is a cutoff valve on the tank fuel supply. Use it religiously! Failure to turn the gas off when not in use can lead to a crankcase full of gasoline and even a bent or broken connecting rod or piston or both from a liquid lock.
If when you pulled the rubber hose off the intake of the carburetor and there was not a rush of gasoline from the bottom of the carburetor you didn't have a problem anyway. There is always going to be a small drip from that drain filter copper thingy in the bottom of the intake. That is why it is there. To allow the excess gasoline to drain out.
If the engine starts it will dry up that small residue in short order. If the engine fails to start and there is only that small residue in the intake and not a large volume of gas then you have other problems. Probably ignition or compression.
I always pour about a table spoon of motor oil into each cylinder through the spark plug hole prior to attempting to start any engine that has has the head off. There is always going to be some grit that lodges between the valve face and the seat face and this along with the same stuff on and around the piston rings etc is going to hold everything away from their sealing surfaces until initial start up blows it out the exhaust along with a lot or smoke from the oil you poured into the cylinder to help seal it up so it would be easier to start.
Don't worry! You won't foul the plugs with new oil on them and besides it wasn't my original idea to do it this way. It was taught to me at the Air Force Reciprocating engine school in Witchataw Falls Texas back in 1955 while I was incarcerated by the Federal Government.
