Gen. output???
8-N Nut
03-02-2004 15:36:52
How does one check voltage output, on three wire Gen.???? TIA.
Bruce (VA)
03-02-2004 18:04:47
 Re: Gen. output??? in reply to 8-N Nut, 03-02-2004 15:36:52
My N's put out 7.4v on the armature & between 3.6-4.6v on the field terminal. Do not try to use a digital meter. Best case is it won't read; worst case is you will burn up the meter.
roger '40 9n
03-02-2004 17:04:51
"How does one check voltage output, on three wire Gen"?
With a voltmeter.
Check the voltage across the battery terminals with the engine not running.
Then start up the tractor and measure the voltage again.
Roger in Michigan
