Order Ford 8N Parts Online
8n/missing and sputtering underload
ray
02-10-2001 18:40:06
my neighbor towed his tractor over yesterday and was not running . had no spark, would not fire and had water in theradiator and oil pan. replaced the coil which had a crack all down the side and pulled the head. replaced the plugs, head gasket and surfaced thehead. tractor then started and after hot drained and changed oil and filter. tractor starts now ,idle and misses when you give her gas. does not want to stay ruunning smoothly. idid clean fuel bowl and have fresh gas.
what else can i do or try that i have not done?
any and all help would really be appreciated.
JerryU
02-11-2001 13:13:45
 Re: 8n/missing and sputtering underload in reply to ray, 02-10-2001 18:40:06
Very obscure, but my 9N would randomly miss under load and cut out. After doing everything, I changed the ignition switch and that fixed it. I would have never believed that that would have acted like that, but then you learn with these tha t nothing surprises you.
JU
ray
02-11-2001 06:11:19
fast ed & phil, thanks for your quick info and updated information on this 8n. i will try to clean and check the complete distributor as both of you mentioned. i'll try that next and see, ray
ray
02-11-2001 06:11:19
ray
02-11-2001 06:10:56
Fast Ed Ohio
02-10-2001 20:51:18
Ray, I am not a pro. you got this old 8 running with a lot of work ( pat on the back )One thing you might check is a lot of up and down slop in the distributer shaft,if the bushings are worn it will cause problems like uneven idle. good luck.
bg
02-10-2001 19:14:24
The carb probably needs cleaning(more than the fuel bowl.) Also the centrifugal advance may not be functioning properly. I'd start with the carb cleaning and adjustment, making sure the plugs, plug wires, points, condensor and rotor and cap are in good condition. If the valves haven't been adjusted, that would be a good idea, too. Do the simple stuff first. That includes fuel filters.
Snowplow
02-11-2001 10:36:09
 Re: Re: 8n/missing and sputtering underload in reply to bg, 02-10-2001 19:14:24
Probably lack of fuel which is either a blockage or poor carb adjustment. Poor combustion (weak spark)could also be the cause which the new plugs and such would fix.
Try adjusting the main knob. Open it up another turn. Cleaning out the filters and such as bg suggested is also good advice. There are a number of inline screens. One in the bowl, one in the tank, and another where the line goes into the carb.
I found that my fuel shut off is broken and I don't get good flow unless I open it all the way up (reserve setting).
Try taking the fuel line off the carb and running some into a can. If you see a poor flow then start looking for the cause, or series of small causes.
ray
02-10-2001 19:37:33
bg, i did also replace fuel filter,plug wires,cap rotor, plugs and points. how does one check the centrifugaladvance and and to what specs do i try to adjust the valves? i am learning to do these repairs as we speak. this is my first attempt at tryin to get the ole tractor a goin. any and all help would be appreciated,ray
Phil (AZ)was(NJ)
02-10-2001 21:29:19
 Re: Re: Re: 8n/missing and sputtering underload in reply to ray, 02-10-2001 19:37:33
Ray, Advance: Remove dist, points, condensor wire,
timing adj screw (on side)& coil. The points Plate is held in place with a retainer (note the position of the loop,allows clearance for coil pigtail)remove the retainer. The outer bushing
and the points plate come out as a unit. (Sometimes tight,need to wiggle) When you have that out the shaft pulls right out. The Weights
& spring assembly allow rotation (CCW) between
the two shafts. Rust,Gunk, Broken Springs
Hope this helps,
