Quality 6 volt battery?
Paul
03-07-2004 17:41:20
Anyone know of a source for a quality 6 volt battery - the ones I get from the local auto store (Kragens) only last 6 -12 months in my 8N.
Thanks for any ideas.
Paul
Arthur Brestlin
03-08-2004 14:33:25
 Re: Quality 6 volt battery? in reply to Paul , 03-07-2004 17:41:20
Paul: In November of 2000 I bought my 2nd 8N. It is a '51. The seller told me that he had replaced the battery 2 years ago and that I should be good for a few years. Was he ever right! It was and still is an Interstate "Workaholic" When my '48 8N needs a battery it will be the same product. My local FNH Dealer sells "their own" brand of 6 volt which he tells me is made in Mexico by Exide. He frankly suggests that I would be much better off to get an Interstate! Between my own experience and my dealers recommendation, I will never use anything but the Interstate Workaholic! I will try to post a hot link to the data sheet for this battery:
Dell (WA)
03-07-2004 19:37:48
Paul..... ..byte my tongue, but John Deere sells a quality tractor rugged 6 volt battery for $50 or so. These batterys are made more rugged inside to JD specs to withstand "off-road" environment.
When my Dodge Cummins Diesel OEM dual battery inst's went south after 5 yrs, (couldn't water the wetcells) I tried to find "Optima" gel batterys $160 ea, not in stock. Dodge Dealer wanted $140 ea for replacement wet cells, not in stock. Sears Die-Hards wanted $120 ea, instock. Interstate wanted $100 ea. Checked the Dodge Cummins TDR bbs, they recommend the John Deere 12 volt batterys. $60 ea. (and you can check the water)
Die-Hards die-eazy..... ..Dell
raytasch
03-07-2004 19:17:17
I've had good luck with NAPA commercial.
ray
Mt Roy
03-07-2004 18:53:02
I would be checking your generator output voltage. If you are overcharging your battery your're killing it youself. I use NAPA automotive 6 volt batteries in a 53 Chev 2ton and 2 N-series tractors and a TO-20 and They seem to outlast the warrenty by a year or so.
souNdguy
03-07-2004 18:20:16
I agree.. see if you have a battery 'only' dealer.. like interstate batteries.. next try a farm store like TSC.. or napa industrial batteries.
Just off hand.. what group size do these batteries fall in? ( for our N's )
Soundguy
dw
03-07-2004 22:56:18
 Re: Re: Quality 6 volt battery? in reply to souNdguy, 03-07-2004 18:20:16
Group 1 are used in the N's.
souNdguy
03-08-2004 05:07:04
 Re: Re: Re: Quality 6 volt battery? in reply to dw, 03-07-2004 22:56:18
thankya
Soundguy
Rob N VA
03-07-2004 18:15:18
Check your phone book for a "Battery Store" Locally here its called "batteries plus" and all they sell is batteries. What you need is a hard core, industrial strength, hairy chested, 6 volter that is rated for agricultural use. Wimpy run of the mill 6 volt batteris are for the old 48 Packard that you drive once a year in the Fourth Of July Parade. If you can't find a battery retailer, try Western Auto, Advance auto, Napa, and just be specific that you want a battery with some muscle!---Rob
Drmeatman
03-07-2004 17:49:05
Bought mine at the local NAPA store.Cost $56 as I remember.No problems.
Paul
03-08-2004 22:31:40
 Re: Re: Quality 6 volt battery? in reply to Drmeatman, 03-07-2004 17:49:05
All,
Thanks for the info - I'll check out the sources and check the charging system.
Should I just check the voltage at the battery terminals and what is the limit for over charging - I still need to get a good manual that has the specs.
Thanks again.
Paul
