Order Ford 8N Parts Online
Steering Problem 8N
PVF
03-14-2004 15:30:32
My 47 8N has a high speed wooble on front end. Causes rods to shake. Seems worse on asphalt surface versus grass etc. Any ideas.
Thanks,
PVF
Dan
03-15-2004 09:05:30
 Re: Steering Problem 8N in reply to PVF, 03-14-2004 15:30:32
I had that problem on my 48 8N when I first got it. The right side toe in was incredible and the whole tire wobbled badly if I grabbed the top of the front tires and pushed/pulled in and out towards the radiator. I have since adjusted the steering sectors, adjusted the right side drag link, replaced a badly worn bearing on one side, and replaced the spindle arm bushings. This has helped considerably. It is not as hard as you would think to do these repairs/adjustments.
Good luck,
Dan
souNdguy
03-14-2004 16:44:04
As was mentioned.. check all the 'outside' parts.. such as tie rod/draglink ends.. wheel bearings, and spindle bushings.
You may also be able to get a little adjustment out of rotating the sector retaining plates... gonna have to pull all those bolts out on either side to see if you can rotate then to a snugger position.
Good luck.
I do recomment an I&T F0-4 manual.. Has pics of all three steering units fron the 9/2/8 n's
Soundguy
scrub
03-14-2004 16:29:22
Use your foot to put slight pressure on the radius rod where it connects to the steering gear. I use my right leg. It will take all the wobble out while you are driving at full throttle in fourth gear. Try it it works.
BlackDirtKid(TX)
03-14-2004 16:18:08
Check the toe in on the front wheels,should be 1/4inch toe in. Are the ends on the drag links wore out? That'll cause a lotta shakin goin on too. Keep her under 50 mph, that'l help LOL
Hope this helps Good luck
BDK Richard
BDK
03-14-2004 16:30:51
 Re: Re: Steering Problem 8N in reply to BlackDirtKid(TX), 03-14-2004 16:18:08
One more thing,ya might check the front wheel bearing adjustment. Loose bearingg kin cause some wobble.
BDK richard
Jack
03-14-2004 15:56:05
Get an FO-4 I&T shop manual and see about adjusting the steering gears.
Jack
Doit
03-14-2004 15:59:41
 Re: Re: Steering Problem 8N in reply to Jack, 03-14-2004 15:56:05
That has the information needed, Also you might want the Master Parts Catalog
DO
RL
03-14-2004 16:19:00
 Re: Re: Re: Steering Problem 8N in reply to Doit , 03-14-2004 15:59:41
My 48 8N has been doing that for years. Early 8Ns had a lousy steering mechanism. Yep, it's actually worse on pavement. You've got a little job ahead of you to rectify it. I just drive a little slower. You may try adjusting the tie rods just a bit so that they are working against each other. I know it's not right but, it beats tearing the whole steering mechanism apart after a new paint job. Good Luck.
