Brush Hog Blades
Ryan MD
03-18-2004 17:27:08
I bought a used brush hog for my 8N. The blades look pretty dull and will need to be sharpened. What is the best way to sharpen the blades? I have immediate access to an angle grinder and could probably get access to a bench grinder.
Thanks,
Ryan
tim in pa
03-19-2004 05:39:56
 Re: Brush Hog Blades in reply to Ryan MD, 03-18-2004 17:27:08
ryan, i raise the hog with the 3ph as high as it will go (shorten the top link). then place several 3'- 4'long boards under the back end to hold it up, you could also chain it up to something. without the tractor running, crawl under with a grinder and grind the edge. i've seen a hog cut when it had almost no bevel at all. keep the edge relative to what you cut. if all you cut is clean lawn/field, a sharper edge can be used. but it will dull quickly if you use it for moving rocks, finding pipes, and landscaping.
RedTail
03-19-2004 10:14:01
 Re: Re: Brush Hog Blades in reply to tim in pa, 03-19-2004 05:39:56
How about as a spark generator....
souNdguy
03-18-2004 20:53:21
I've always swung them around and used an angle grinder on mine...Never had a balance problem.. just don't go crazy with the grinder.. just reshape back to a good inclined plane with a thin edge.. doesn't need to be razor sharp.. and if it is.. it will fold over to easy anyway.. remember you are cutting brush and rocks.. etc... anything other than a 1/8 inch rounded flat is gonna cut grass..
Soundguy
Upper Peninsula, Mich
03-18-2004 17:40:31
Ryan. Some sharpen them with an angle grinder without removing the blades from the hog. I take them off, sharpen them on a bench grinder, weigh them so they are balanced properly. Your choice. Ron
