Ford Loader cylinder leaks
9N'er
03-19-2004 06:15:34
Need some advice to stop a leak or, to use some sort of material to seal the threads on the lift cylinders for my Ford FEL.
The main lift cylinder requires a constant tightening of the cylinder end to stop a leak. Is there some sort of sealant I can use on the threads to stop the leak?
The leak comse from around the threads.
It requires a 2 1/8" wrench to tighten that cylinder end where the piston/rod enters into it.
Thanks. 9N'er
mel
03-19-2004 23:15:10
 Re: Ford Loader cylinder leaks in reply to 9N'er, 03-19-2004 06:15:34
Strips made from pantyhose make good packing
BOB
03-19-2004 17:19:17
9ner,what i did on mine was to use some soft cloth line rope,leave old packing in there ,put rope in and tighten yeha no more leaks
North of Fargo
03-19-2004 14:41:39
Try this stuff. Sold in cases of 12 or contact them for free sample.
http://www.sealweld.com/sealex.htm
Mike OH
03-19-2004 06:44:08
9N'er you could probably use teflon tape to seal the threads, but what you really need to do is add to or change the packing which is doing the leaking. You get the packing fixed and the threads will stop leaking all by themselves. Good luck.
