Need carburator fix advice on 48-8N. I've read about the electrical problems maskerading as carb problems but think this may actually be a carb problem - I'll try to explain.HISTORY: Bought tractor 4 yrs ago. The man I bought it from purchased and installed a brand new carb ($200) because he thought the original carb was bad (it was gunk in the tank). From the time I bought it I've had to run with the choke half way out and it will run fairly smooth. With choke in it will stumble and die at low idle immediately and barely run at high idle. Four years ago I took the carb apart and blew out all ports with carb cleaner (carb was 3 weeks old and appeared spotless) but absolutely no change or improvement. I checked for manifold leaks by spraying WD40 around carb and manifold - no change. Checked and reset timing - no change. Finally I gave up. Help/Questions: Ok so now I have the carb off again because I've got to get it fixed proper. 1. The carb #on stamp is: RE-TSX241B / RE-8N9510C. Is this a Marvel Schebler carb? 2. The cast housign and parts on the carb all seem to be outstanding quality and workmanship and the carb still is really clean internally. Should I soak in general carb cleaner over night and then flush the passages out just incase their is some unsean spec causing this grief? 3. Are the jets in the carb changeable - would this explain the extreme lean condition if someone had smaller jets installed? 4. Do you agree that this is a carb problem if 1/2 choke can create a rich enough mixture to get fairly smooth low idle and high idle? 5. Any other advice? Thanks so much for your help - I really want to get this running correctly - hard to really enjoy it in this condition.
Paul
