Yes.. 134d is a fine ( but thinner ) substitute for the 90wt gl-1. And if your lift and seals are in good condition.. you will get better/faster cold weather performance out of it. Do you have a wallmart nearby? They sell a universal transdraulic oil that does meet the 134d spec. So does car quest.. TSC, and anyone carrying fina products has a uni-tran oil that also meets those specs. No.. don't have to remove the shifter.. but you do have to finagle with the bot a bit. First of all.. on the boot.. think of it as a cylinder sleave.. 'interference fit'.. etc 2 prevailing methods have arisin. 1, is if you have a castration / tail docking tool ( calves / lambs.. etc ) that spreads those real tiny rubber bands... it has 4 tongs that you can use to spread the boot over the 'seat' on the shifter. 2nd and possibly easier for those without the tool, is to boil a pan of water.. take off the burner, and pop the rubber boot in. Walk out to the tractor that already has a cleaned up boot area... then fish the boot out of the water.. and slide it on.. should be pliable enough to go eash.. berhaps a bluntscrewdriver may halp.. etc. Soundguy
