Hydraulic lift capacity
Al Amstutz
02-13-2001 11:08:36
I have read carefully thru my books,service manual and owner's manual. I can't seem to find a capacity for the hydraulic lift on my 8N. Do I need to be concerned about trying to lift too much weight (logs, barrels of "stuff", cement blocks etc) with the 3 pt hitch. I suppose the limit is what will lift the front wheels but aside from that can lifting too much damage the pump or arms?
Thanks Al
Makedo
02-13-2001 16:51:53
 Re: Hydraulic lift capacity in reply to Al Amstutz, 02-13-2001 11:08:36
If your hyd's will pick it and you can steer it you won't hurt it.
bg
02-13-2001 13:56:26
The capacity is around 700-800 lbs, but that is all a function of leverage and weight distribution. The farther from the tractor, the less it can lift.
