Oil pressure/restored
ANT
02-13-2001 16:48:22
Thanx for advice.Received service manual.
noted that in cold weather you can add kerosene to oil.10% We presume it eventually evaporates off
when engine heats up and you have to add real
oil to compensate. Tractor had been sitting
4 months.Took line off gauge and jury rigged
rubber hose and funnel on to line.With a 3 foot
Hydrostatic head above the engine I poured in first 1 1/2 cups of warm 5/20 wt followed by 1 cup
of cold 30 wt. Started engine. Ha! 10lbs oil
pressure.In retrospect the oil filter does the same thing normally.... acts as a resevoir
to re prime the pump. Yet this tractor's oil pump gear wear ,may put it at a disadvantage
for sucking from pan and needs a head start.
