HEY DELL!
9NJoe
03-31-2004 05:22:56
Dell,
I am going to split my 9N to fix the tranny input seal. If you were going to split a tractor, what else would you do? Any other seals or stuff I should replace while I am in there? I am thinking that since the clutch must be blocked to prevent sticking that I will probably be replacing the friction disc. Any other things I should think about? thanks in advance.
Joe
Fred
03-31-2004 16:13:56
 Re: HEY DELL! in reply to 9NJoe, 03-31-2004 05:22:56
Check the ring gear. They always wear.
TennesseeMan
03-31-2004 07:25:34
When I split my 8N last month. I went ahead and replaced the pilot bearing and the throwout bearing while it was tore down. They both didn't seem real smooth. Pretty cheap preventive maintenance.
Pilot bearing...John,PA
03-31-2004 07:08:20
What Dell say, plusl you might consider at least inspecting the pilot bearing. Lots of times the bearing is frozen and turning on the shaft.
Just a thought.
Dell (WA)
03-31-2004 07:03:50
Joe..... ....remember that the clutch has an "off-set" hub, so you install it with longside of hub facing AWAY from flywheel. Most replace the throw-out bearing because of the hassle of re-doing it if bad.
Use your 4-bolt removed tranny input shaft to "center" your clutch disc while you also replace the tranny input seal ($3, cheap).
Unless you have SERIOUS flywheel and pressure plate scoring problems, (usually from worn clutch rivets) a light sanding to remove the shinning is all that is needed.
Follow the I&T FO-4 clutch proceedures and you'll be fine..... ....Dell
