Over run clutch
Andy MN
02-13-2001 16:55:06
I bought an over run. The directions said to remove the grease fitting and put a pin through it connecting it to the PTO shaft. There was no pin included. What kind of pin do I need?
I know you guys have the answer.
Bill (VA)
02-13-2001 17:13:54
 Re: Over run clutch in reply to Andy MN, 02-13-2001 16:55:06
I had the very same problem! As I remember it was a 5/16 by 2 inch long roll pin (maybe called a split pin)... anyway it was a common size at the local hardware store. I think I used a drill bit to check the diameter required.
Dell (WA)
02-13-2001 17:22:46
 Re: Re: Over run clutch in reply to Bill (VA), 02-13-2001 17:13:54
Good call..... 5/16 X 2 roll pin. Make certain you center the pin so the outer shell of the ORC spins. This may be a little "tight" on a new ORC but it should be hand twistable..... ...Dell, the self-appointed ORC Safety Preacher
